[Qgis-user] GeoJSON coordinate precision
Werner Macho werner.macho at gmail.com
Tue Sep 15 04:57:23 PDT 2020
Hi Christoph,
back in front of my PC there is room for further explanation ;)
if you right click on the layer to export and go to "Export" -> "Save
Features As" the Export window opens ..
If you scroll down a bit there are "Layer Options" - and within the
Layer Options (depending to which format you want to export, but you
said GeoJSON - and within GeoJSON I just checked that the option is
really there) there is the "COORDINATE_PRECISION" Option in the first
line (followed by RFC7946 and WRITE_BBOX).
Default should be 15 as precision ..
Hope this helps
regards
Werner
On Tue, Sep 15, 2020 at 1:51 PM Christoph Jung <jagodki.cj at gmail.com> wrote:
> Hello Werner,
> Thank you for your response. I looked for a parameter like coordinate_precision, but I could not find anything similar in the export dialogue (for GeoJSON), in the application options also not.
> Christoph
> > Am 15.09.2020 um 11:40 schrieb Werner Macho <werner.macho at gmail.com>:
