[Qgis-user] pdf generation not working
Davide
d at vide.bz
Thu Sep 17 03:35:33 PDT 2020
we are using the qgis web client 2, but when we request the pdf, then an
error occours. Debugging the request we see that the qgis server, that
uses qgis_mapserv.fcgi return error 500 (tested directly with curl).
We have tried to enable logging like
QGIS_SERVER_LOG_FILE
QGIS_SERVER_LOG_LEVEL
but logs are always empty.
With this situation we can't understand where the problem is.
Any suggestion about how to enable logging and/or why the pdf can return
and error 500 ?
Thanks in advance for any help!
Davide Montesin
Italy
