[Qgis-user] Reliable geocoding alternative?
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Tue Sep 22 16:41:07 PDT 2020
Why not just use "Join Attributes by Location" or "Join Attributes by
Field Value" in Processing? If you have inconsistent results, I would
look at your data base. Are you using unique fields? Do you have
duplicate shapes or shape collections (MultiPoints, Mulit...)? What
method are you using? intersects, within... ?
Nicolas
On 2020-09-22 7:19 p.m., Erich Purpur wrote:
> Hi all-
> Geocoding is the one process I am still doing in ArcPro. Most of the
> QGIS geocoding tutorials I have found recommend using the Geocoding
> tool in MMQGIS but I have really struggled to get consistent results.
> Does anyone have an alternative Geocoding plugin or other tool they
> use? It doesn't have to be within QGIS, an external tool would be fine.
> Thank you,
> Erich Purpur
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200922/96fa6598/attachment.html>
