[Qgis-user] Afther update QGis 3.14.15-1 to QGis 3.14.16-1 python error..!!
magerlin MAP at ramboll.dk
Wed Sep 23 03:18:10 PDT 2020
Now there is a version 2.14.16-2
Do not know whether it is the same issue but it cannot be started up:
Stack Trace
PyTuple_Size :
PyInit_QtCore :
QObject::inherits :
qt_plugin_query_metadata :
QWidget::event :
QApplicationPrivate::notify_helper :
QApplication::notify :
QgsApplication::notify qgsapplication.cpp:439
QCoreApplication::notifyInternal2 :
QWidget::ensurePolished :
QWidget::event :
QCoreApplicationPrivate::sendPostedEvents :
QEventDispatcherWin32::processEvents :
UserCallWinProcCheckWow :
DispatchMessageWorker :
QEventLoop::exec :
QDialog::exec :
QgsMessageViewer::showMessage qgsmessageviewer.cpp:70
QgsPythonUtilsImpl::runString qgspythonutilsimpl.cpp:352
QgsPythonRunnerImpl::runCommand qgisapp.cpp:11784
QgsPythonRunner::run qgspythonrunner.cpp:33
QgisApp::QgisApp qgisapp.cpp:1412
main main.cpp:1364
BaseThreadInitThunk :
RtlUserThreadStart :
QGIS Info
QGIS Version: 3.14.16-Pi
QGIS code revision: df27394552
Compiled against Qt: 5.11.2
Running against Qt: 5.11.2
Compiled against GDAL: 3.0.4
Running against GDAL: 3.0.4
System Info
CPU Type: x86_64
Kernel Type: winnt
Kernel Version: 10.0.17763
Regards Morten
Currently using Qgis 3.14.15
Windows 10, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
