[Qgis-user] PyQGIS: wipe all xyz connections
Erich Purpur epurpur at gmail.com
Wed Sep 23 09:54:15 PDT 2020
Is this regarding the following stackoverflow thread?
https://gis.stackexchange.com/questions/374808/pyqt5-wipe-xyz-connections
If so, your error message as you posted it in StackOverflow is:
for group in getGroupXYZ(self): NameError: name 'getGroupXYZ' is not defined
>From what I gather in the code posted in SO, you are trying to iterate over
getGroupXYZ(), which is a function. This is not an object which holds
multiple items, which is the purpose of a loop. However, in your
getGroupXYZ() function, you return an object called groupsXYZ. You should
loop of the groupsXYZ object, not the function.
-Erich
On Wed, Sep 23, 2020 at 11:38 AM 1520 gis <
juliermeopensourcedeveloper at gmail.com> wrote:
> Dear all,
> I am writing a PyQT5 QGIS Plugin to wipe out all xyz connections available
> in QGS projects.
> I wrote the code below, but I am not achieving my goal and I did not
> understand the structure of xyz connections.
> def removeAllConnectionsXYZ(self):
> s = QSettings()
> xyz = 'qgis/connections-xyz'
> groupsXYZ = s.childGroups()
> for group in groupsXYZ:
> s.beginGroup(xyz)
> s.remove("")
> s.endGroup()
> self.dlg.wipeAllConnectionsXyz.clicked.connect(
> self.removeAllConnectionsXYZ)
> # Any comment will be very appreciated.
> #Thank you for your time in advance
> #Julierme
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200923/3f4cf743/attachment.html>
