[Qgis-user] QGIS Update 3.14.16
Martin Bittens martin.bittens at gmx.de
Fri Sep 25 04:08:50 PDT 2020
Hello Andrea,
thanks a lot for your response. It is working as well. Great!
Just to understand, why this path has been defined in the installations
of the "QGIS with GRASS" packages? Is there any relation between
"RStudio" and "QGIS with GRASS"?
Regards
Martin
Am 9/24/2020 um 8:12 PM schrieb Andrea Giudiceandrea:
> Hi Martin,
> in alternative to the working solution proposed by Bas, you could remove
> ";C:\Program Files\RStudio\bin" from the PATH string in the file
> qgis-bin-g7.env (for QGIS 3.14) which is in your %OSGEO4W_ROOT%\bin folder.
> Regards.
> baswein wrote
>> I don't use RStufdio often so what fixed it for me was to change the
>> Rstudio
>> folder to RStudioX.
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
