[Qgis-user] How to make a table in a subsection report
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Wed Aug 18 00:05:51 PDT 2021
I only faintly remember making a report last year with a similar problem
(maps of photo destinations on different sections of a highway).
I think I solved it by adding new columns of combined indices with the
subsection (your grid) and the photo-id, because there way no way to do
this within the report.
Haven't touched the tool since then, cause every redecision on how to
design the report lead to a complete new start from scratch, which took
too much time.
Not sure if it hits your problem. As I said, can't remember well.
Good luck,
Bernd
On 18.08.21 08:53, Dario wrote:
> Hi, I have a report with a primary dynamic section where I have a map with a controlled layer (indexed grid). Inside each map I have points (sometime one, sometime more).
> I need to make a subsection with these points (each point has the same indexed grid name, so I can maintain the same order of the map).
> The issue is it is requested to make two table (form) for each page and I don’t know if it is possible or not. I mean... what’s happen when I have only one table and how it recognise the sequence between first and second item in the same page?
> Sorry if I was not so clear...
> Thank you in advance for your help
> Cheers
> _
> Qgis-user mailing list
