[Qgis-user] MapInfo export issue
Paul Wittle paul.wittle at dorsetcouncil.gov.uk
Wed Dec 1 00:41:04 PST 2021
We have tested an the projection was set correctly in version 3.16.0 but it is now as you say for version 3.16.14. Are you saying this is a deliberate ‘feature’ in version 14 as we have MapInfo users as well as QGIS and this makes things harder when trying to export to tab as the result is now incorrect and requires a further alteration to set the CRS?
Thanks,
Paul
Sent: 30 November 2021 22:54
To: Paul Wittle <paul.wittle at dorsetcouncil.gov.uk>
Subject: Re: [Qgis-user] MapInfo export issue
Dear PAul,
QGIS exports MapInfo 3 compatible TABs or MIFs in non-earth CRS. You can check it if you export your layer to MIF/MID.
The hedor of the MIF file:
Version 300
Charset "Neutral"
Delimiter ","
CoordSys NonEarth Units "m"
I use QGIS 3.22.1 on Ubuntu.
Regards,
Zoltan
Paul Wittle <paul.wittle at dorsetcouncil.gov.uk<mailto:paul.wittle at dorsetcouncil.gov.uk>> ezt írta (időpont: 2021. nov. 30., K, 19:04):
I was just about to try and push out version 3.16.14 but it has been pointed out that if you export to MapInfo tab file it is no longer saving the projection in the output.
Is anyone else finding that the resulting files are doing this and is there a work around using say gdal options?
Sorry if I missed another message about this as I see the Windows build has been proving problematic and we are Windows users,
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/data-protection<http://www.dorsetcouncil.gov.uk/data-protection>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Üdv.
Siki Zoltán
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211201/6cea0ff4/attachment-0001.html>
