[Qgis-user] MapInfo export issue
Nicolas Cadieux njacadieux.gitlab at gmail.com
Wed Dec 1 09:41:25 PST 2021
If you send us a simple file (the original, the tab and mid mif version you created),  we could test on other versions of QGIS.  If you do this make sure we can correctly identify the proper location.  Use something like the outline of a building that we can find using Google earth as background image.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 1 déc. 2021 à 12:05, Paul Wittle <paul.wittle at dorsetcouncil.gov.uk> a écrit :
> Hi,
> I’ve tried exporting to MIF instead of a tab file and it generates an error of “Found [region] while searching for [version]” when you try to load it into the MapInfo. The output is also creating an error when QGIS tries to load the data as well although I’m not sure if QGIS could ever directly load MIF files.
> The main issue is that if you save to TAB and select “Add saved file to map” it draws in a different place. This feels a bit wrong to me.
> In any case we are trying to get people to upgrade to the latest version of MapInfo so GeoPackage is supported. I will just advise our users to export to GeoPackage instead and use that as the main data sharing format instead.
> Thanks for all the tips and suggestions though.
> Paul
> This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/data-protection _______________________________________________
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211201/48a7cca1/attachment.html>
