[Qgis-user] MapInfo export issue
Paul Wittle paul.wittle at dorsetcouncil.gov.uk
Thu Dec 2 00:05:08 PST 2021
Morning,
That tool seems to be saving as I would have expected thank you for the tip 😊
I’ve told the users to use that tool instead of right click > export for now.
Cheers,
Paul
From: Richard Greenwood <richard.greenwood at gmail.com>
Sent: 02 December 2021 00:37
To: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
Cc: Paul Wittle <paul.wittle at dorsetcouncil.gov.uk>; qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] MapInfo export issue
I don't know if this is related or helpful, but GDAL 3.0 doesn't produce MapInfo TAB files with the correct coordinate system when the coordinate system is in feet. GDAL 3.3 and 3.4 do work.
A suggestion would be to install GDAL 3.3 or 3.4 and use
ogr2ogr -f "MapInfo file" dest source
On Wed, Dec 1, 2021 at 10:41 AM Nicolas Cadieux <njacadieux.gitlab at gmail.com<mailto:njacadieux.gitlab at gmail.com>> wrote:
If you send us a simple file (the original, the tab and mid mif version you created),  we could test on other versions of QGIS.  If you do this make sure we can correctly identify the proper location.  Use something like the outline of a building that we can find using Google earth as background image.
Nicolas Cadieux
https://gitlab.com/njacadieux
Le 1 déc. 2021 à 12:05, Paul Wittle <paul.wittle at dorsetcouncil.gov.uk<mailto:paul.wittle at dorsetcouncil.gov.uk>> a écrit :
I’ve tried exporting to MIF instead of a tab file and it generates an error of “Found [region] while searching for [version]” when you try to load it into the MapInfo. The output is also creating an error when QGIS tries to load the data as well although I’m not sure if QGIS could ever directly load MIF files.
The main issue is that if you save to TAB and select “Add saved file to map” it draws in a different place. This feels a bit wrong to me.
In any case we are trying to get people to upgrade to the latest version of MapInfo so GeoPackage is supported. I will just advise our users to export to GeoPackage instead and use that as the main data sharing format instead.
Thanks for all the tips and suggestions though.
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/data-protection<http://www.dorsetcouncil.gov.uk/data-protection> _______________________________________________
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Richard W. Greenwood
www.greenwoodmap.com<http://www.greenwoodmap.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211202/37b2c8bd/attachment.html>
