[Qgis-user] MapInfo export issue
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Thu Dec 2 03:27:39 PST 2021
Hi Paul -
It's maybe not pertinent to case but I tried to export a Postgres-based
layer to both the MapInfo MIF and Tab file-formats and showing the
layers afterwards in QGIS - but using QGIS v. *3.22* on Windows 10. It
worked perfectly.
I checked the first part of the generated MIF text file. It looked fine
and contained all the necessary parts in the header : version info,
projection info and data structure info.
Regarding your MapInfo error when reading  MIF/MID: It is probably
caused by the MIF-file is missing  "Version 300" as the first line -
causing the MapInfo interpreter to look after it until it find the first
"Region"  definition in the file (MapInfo speak for polygon).  Why, I
don't know... But QGIS v. 3.16 is a strange beast.
Did you check if the projection was correctly set in the "Save features
as" dialog before exporting the data ?
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 01-12-2021 kl. 18:04 skrev Paul Wittle:
> Hi,
> I’ve tried exporting to MIF instead of a tab file and it generates an
> error of “Found [region] while searching for [version]” when you try
> to load it into the MapInfo. The output is also creating an error when
> QGIS tries to load the data as well although I’m not sure if QGIS
> could ever directly load MIF files.
> The main issue is that if you save to TAB and select “Add saved file
> to map” it draws in a different place. This feels a bit wrong to me.
> In any case we are trying to get people to upgrade to the latest
> version of MapInfo so GeoPackage is supported. I will just advise our
> users to export to GeoPackage instead and use that as the main data
> sharing format instead.
> Thanks for all the tips and suggestions though.
> Paul
> This e-mail and any files transmitted with it are intended solely for
> the use of the individual or entity to whom they are addressed. It may
> contain unclassified but sensitive or protectively marked material and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All
> traffic may be subject to recording and/or monitoring in accordance
> with relevant legislation. Any views expressed in this message are
> those of the individual sender, except where the sender specifies and
> with authority, states them to be the views of Dorset Council. Dorset
> Council does not accept service of documents by fax or other
> electronic means. Virus checking: Whilst all reasonable steps have
> been taken to ensure that this electronic communication and its
> attachments whether encoded, encrypted or otherwise supplied are free
> from computer viruses, Dorset Council accepts no liability in respect
> of any loss, cost, damage or expense suffered as a result of accessing
> this message or any of its attachments. For information on how Dorset
> Council processes your information, please see
> www.dorsetcouncil.gov.uk/data-protection
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211202/fbef611f/attachment-0001.html>
