[Qgis-user] Buffer by Attribute Issue
chris hermansen
clhermansen at gmail.com
Wed Dec 15 15:41:49 PST 2021
Peter and list,
On Wed, Dec 15, 2021 at 7:26 AM Peter Devanney <peter at devanney.ca> wrote:
> Hi Folks
> Have a table full of points that I want to buffer by a variable distance.
> The distance is an attribute in the input table in km.
> Using Vector>Geoprocessing>Buffer It works fine if I specify a fixed
> buffer.
> When I run it with the attribute selected it runs fine but it will not
> paint the buffers. At first I thought I had a unit issue so added an
> expression to multiply the attribute by 1000 to get to km from m as I
> wasn't sure if the default was m.
> The buffered output behaves totally normally so I can label, and zoom to
> features... All looks fine except no actual buffers draw. Symbology panel
> looks normal.
> Just wondering if anyone has seen this or knows of a workaround or
> thoughts on what I am doing wrong.
> What is the type of your buffer item? What are the typical values?
What is your CRS?
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211215/7702ddf2/attachment.html>
