[Qgis-user] OGR VRT issue?
Jorge Gustavo Rocha
jgr at geomaster.pt
Mon Dec 20 02:12:19 PST 2021
Hi Brent,
I've reproduced this issue. ogrinfo/ogr2ogr works, but QGIS is unable to
read it properly.
Please fill a bug report.
Regards,
Jorge Gustavo
On 20/12/21 02:11, Brent Wood wrote:
> Hi,
> I'm looking to open a sqlite3 (not spatialite) database in QGIS.
> I have a table in the db with a lat column & a lon column with
> EPSG:4326 coordinates
> I have written a VRT file to enable opening the table with a virtual
> geometry column. This works fine with ogrinfo on the command line, but
> creates an empty layer with no geometry type, columns or features in
> QGIS.
> The VRT file contains:
> <OGRVRTDataSource>
> <OGRVRTLayer name="test">
> <SrcDataSource>test.db</SrcDataSource>
> <SrcLayer>test</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>WGS84</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="lon" y="lat"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> Testing with ogrinfo is successful, the text returned is below.
> The table contents are:
> sqlite> select * from test;
> id|lat|lon
> 1|-41.354|174.567
> Can anyone explain why this fails in QGIS?
> I'm running QGIS v3.16.11 on Linux (deb platform)
> Thanks,
> Brent Wood
> ogrinfo result:
> ogrinfo -geom=YES -al test.vrt
> INFO: Open of `test.vrt'
> using driver `OGR_VRT' successful.
> - 'VirtualXPath' [XML Path Language - XPath]
> Layer name: test
> Geometry: Point
> Feature Count: 1
> Extent: (-41.354000, 174.567000) - (-41.354000, 174.567000)
> Layer SRS WKT:
> GEOGCRS["WGS 84",
> DATUM["World Geodetic System 1984",
> ELLIPSOID["WGS 84",6378137,298.257223563,
> LENGTHUNIT["metre",1]]],
> PRIMEM["Greenwich",0,
> ANGLEUNIT["degree",0.0174532925199433]],
> CS[ellipsoidal,2],
> AXIS["geodetic latitude (Lat)",north,
> ORDER[1],
> AXIS["geodetic longitude (Lon)",east,
> ORDER[2],
> ID["EPSG",4326]]
> Data axis to CRS axis mapping: 2,1
> FID Column = rowid
> lat: Real (0.0)
> lon: Real (0.0)
> OGRFeature(test):1
> id (Integer) = 1
> lat (Real) = -41.354
> lon (Real) = 174.567
> POINT (-41.354 174.567)
> <https://www.niwa.co.nz> Brent Wood
> Principal Technician - GIS and Spatial Data Management
> Programme Leader - Environmental Information Delivery
> +64-4-386-0529
> National Institute of Water & Atmospheric Research Ltd (NIWA)
> 301 Evans Bay Parade Hataitai Wellington New Zealand
> *Connect with NIWA:* niwa.co.nz <https://www.niwa.co.nz> Facebook
> <https://www.facebook.com/nzniwa> LinkedIn
> <https://www.linkedin.com/company/niwa> Twitter
> <https://twitter.com/niwa_nz> Instagram
> <https://www.instagram.com/niwa_science>
> To ensure compliance with legal requirements and to maintain cyber
> security standards, NIWA's IT systems are subject to ongoing
> monitoring, activity logging and auditing. This monitoring and
> auditing service may be provided by third parties. Such third parties
> can access information transmitted to, processed by and stored on
> NIWA's IT systems
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211220/c38b9d1f/attachment.html>
