[Qgis-user] Detail-level of exported maps
Patrick Dunford enzedrailmaps at gmail.com
Thu Feb 4 16:42:21 PST 2021
You can control the display of labels in the GIS and composer by
specifying scale based rules for labelling
On 5/02/21 2:01 am, Frederik Franke wrote:
> Dear QGIS users,
> I’m relatively new to QGIS and need a quick help to export a map (as
> pdf) from the QGIS composer.
> My map contains an OpenStreetMap background map and I have the problem
> that the exported OpenStreetMap is much too detailed (e.g. hundreds of
> village names are included with a very small font size). When I change
> the export resolution from 300 dpi to 72 dpi in the composer I can
> circumvent this problem. Only big cities are labeled now and the city
> names are in an appropriate size. Unfortunately the map has a very bad
> resolution now (I can see single pixels when I set the pdf-zoom factor
> to 100 percent).
> How can I export a map with a lower detail-level but a good resolution?
> Thanks and best
> Fred
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210205/bee30b32/attachment.html>
