[Qgis-user] Best practice, database vs WFS
Andrea Aime andrea.aime at geo-solutions.it
Thu Jan 7 01:53:39 PST 2021
On Wed, Jan 6, 2021 at 5:16 PM Bernhard Ströbl <bernhard.stroebl at jena.de>
wrote:
> Alessandro already. The data are in an XML format (GML) which is _slow_
> compared to data from a database
GML is the default format, but a WFS server can deliver other formats with
better performance.
For example, GeoServer currently has a community module
<https://docs.geoserver.org/latest/en/user/community/flatgeobuf/installing.html>
that adds a FlatGeoBuf <https://github.com/flatgeobuf/flatgeobuf> WFS
output format.
If QGIS could use it for reading*, then at least part of the performance
issue could be solved.
Cheers
Andrea
*: this likely requires some development, but GDAL/OGR has support for
FlatGeoBuf <https://gdal.org/drivers/vector/flatgeobuf.html>, so hopefully,
not
too much extra effort.
== GeoServer Professional Services from the experts! Visit
http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf
Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa
(LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210107/22f0aaee/attachment.html>
