[Qgis-user] Training manual - 9.1.3. Configuring Additional Plugin Repositories
Inna Nogeste nogeste at outlook.com
Thu Jan 14 04:39:03 PST 2021
Yes, I’ll create an issue, or perhaps issues, where I can’t find the solutions myself, for example missing/old URLs, and try to update documentation with 1 fix/day. There are alot of fixes and don’t know if they can all be listed and done within 1 issue?
Regards,
Inna
Skickades från E-post<https://go.microsoft.com/fwlink/?LinkId=550986> för Windows 10
Från: Alexandre Neto<mailto:senhor.neto at gmail.com>
Skickat: den 13 januari 2021 14:05
Till: Inna Nogeste<mailto:nogeste at outlook.com>
Kopia: qgis-user<mailto:qgis-user at lists.osgeo.org>
Ämne: Re: [Qgis-user] Training manual - 9.1.3. Configuring Additional Plugin Repositories
If you can, please create an issue on github suggesting the corrections.
A terça, 12/01/2021, 18:15, Inna Nogeste <nogeste at outlook.com<mailto:nogeste at outlook.com>> escreveu:
I’ve seen that most of the plugins are in the repository, this is an example in the tutorial which could be deleted, else include a source which has plugins not included in the repository if it is important to show this stage.
Regards,
Inna Nogeste
Skickat: den 11 januari 2021 19:45
I think most of the plugins are now available on qgis official repository.
Alexandre Neto
A segunda, 11/01/2021, 17:48, Inna Nogeste <nogeste at outlook.com<mailto:nogeste at outlook.com>> escreveu:
QGIS 3.16 – Faunalia plugins
This step teaches how to configure a plugin respository from Faunalia
https://docs.qgis.org/3.16/en/docs/training_manual/qgis_plugins/fetching_plugins.html#basic-fa-configuring-additional-plugin-repositories<https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.qgis.org%2F3.16%2Fen%2Fdocs%2Ftraining_manual%2Fqgis_plugins%2Ffetching_plugins.html%23basic-fa-configuring-additional-plugin-repositories&data=04%7C01%7C%7C488d15a35c934390b81f08d8b7c3db2c%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637461399106205590%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=HW6Zh1MR8jpfTKH4OrsWGyeZ%2FxAJRXC0U7rVIkz1ZaE%3D&reserved=0>
however I’m getting the following error message:
“Error reading repository:Fanualia
Server response is 200 OK, but doesn’t contain plugin metadata. This is most likely caused by a proxy or wrong repository URL. You can configure proxy settings in QGIS Options.”
 The URL in the training manual no longer exists and the plugins are located here instead:
https://www.faunalia.eu/en/dev/plugins<https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.faunalia.eu%2Fen%2Fdev%2Fplugins&data=04%7C01%7C%7C488d15a35c934390b81f08d8b7c3db2c%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637461399106215584%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=ivKJoRhY%2B0ff3oyYUN207V%2B%2FFMerOq90bPAraL0JkTs%3D&reserved=0>
 Does anyone (from Faunalia?) know what the URL should be or what needs to be edited in the Proxy settings for this to work? I’ll then be able to edit this step in the doucmentation GitHub with the correct info.
 Regards,
Inna Nogeste
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7C%7C488d15a35c934390b81f08d8b7c3db2c%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637461399106215584%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=N5CsMY8Cq0n2jKq9KO67QGhSWZzKSh7KbYvjE2aDd%2Bw%3D&reserved=0>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7C%7C488d15a35c934390b81f08d8b7c3db2c%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637461399106225581%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=UkW6alR%2FlHHSAWwonmSszftpRlIcgO3yceDTNlporeQ%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210114/2e114024/attachment.html>
