[Qgis-user] PDAL to the rescue
Luigi Pirelli luipir at gmail.com
Sat Jul 3 00:54:29 PDT 2021
completly agree with you. W PDAL :)
I strongly suggest to automize your processes. creating json pipelines and
consume them creating python/processing scripts using pyton interface to
PDAL (can be named pyPDAL?).
Is this your use case? tell us more or better prepare a UseCase story that
can be published in QGIS pages.
regards
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Book: Mastering QGIS3 - 3rd Edition
<https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
* Hire a team: http://www.qcooperative.net
On Sat, 3 Jul 2021 at 01:48, Drew French <fullboarfarm at gmail.com> wrote:
> I just wanted to share a quick story with you - I recently switched over
> to Linux from Windows and it has been interesting - overall very positive
> but a definite learning curve going on here. I was just beginning to work
> with LIDAR data and I realized I hadn't set up LASTools and Fusion in QGIS
> 3.20 and I quickly learned this was not going to be an easy endeavor on a
> Linux machine. As I use point clouds fairly often this was alarming. But
> then I remembered that 3.20 has LIDAR support built in, and I quickly
> opened up a las file and found it to be easy and intuitive to use if you
> know the QGIS GUI. Styling and so on is a breeze, and I huge thank you from
> me to the developers as I am sure this was a large amount of work to bring
> to fruition.
> But then I realized that I didn't have any of my old tools to create DEMs
> and that was one of the most important things I do on a weekly basis with
> point cloud data. I began to look into PDAL and was able to simply create a
> quick DEM using PDAL in my terminal following a tutorial online. That was
> actually easier and simpler than my other workflow, so now I will be
> learning more about PDAL as I go forward.
> Just wanted to note that it seems that if you are willing to learn how to
> use PDAL, then it seems to me that LASTools and Fusion are kind of obsolete
> with this new version of QGIS. Let me know if that seems accurate.
> Thanks again to all the developers of QGIS,
> Andrew French
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210703/7cbbce2e/attachment.html>
