[Qgis-user] Combining two layers
Nicolas Cadieux njacadieux.gitlab at gmail.com
Fri Jul 9 10:48:03 PDT 2021
You can also simply cut and paste.  Click on the first layer, select all, click on the second layer, make sure it is editable, then  paste.  I believe the merge method is probably better for bigger data sets.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 9 juill. 2021 à 13:37, L.W. <eaglelw at gmx.de> a écrit :
> Go to "Processing Toolbox" and search for "merge vector layers" ... this should do the trick.
> Am 09.07.2021 um 19:00 schrieb Michael Williamson:
>> I have data in two layers which have identical structures. How do I combine the data into a single layer?
>> Probably a very simple question but I simply cannot find out from the documentation how to do it.
>> Michael Williamson
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210709/3193b257/attachment.html>
