[Qgis-user] Raster layer properties panel issue
Nicolas Cadieux njacadieux.gitlab at gmail.com
Fri Jul 9 10:56:05 PDT 2021
I had that before, a long time ago, when a layer property was open on the histogram tab.  I had very big file and that took 10 min to calculate the full histogram.  A think if you open a small raster, and click on the properties, select the first tab on the top then close it.
This way, QGIS will open the first tab on top by default. If that does not do it, try creating a new user profile.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 9 juill. 2021 à 08:59, Isabelle Lanzrein <isabelle at lanzrein.de> a écrit :
> Hi,
> Since yesterday, my QGIS 3.8.3 Zanzibar Application freezes when try to open the properties panel for any raster layer, and I have to force quit the programme. It works fine for opening vector layer properties. I am using macOS Catalina 10.15.5 and have not done any updates recently. I have tried updating to QGIS 3.16 Hannover, but the same thing happens. I have tried many different raster files so I don’t think it’s an issue with the files. Is there any way I can get around this?
> Thank you,
> Isabelle
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210709/47339faf/attachment.html>
