[Qgis-user] Import Kmz without losing the symbology
C Hamilton adenaculture at gmail.com
Wed Jul 14 11:14:03 PDT 2021
I would need to see an example of your kmz to know whether it is an issue
with KML Tools or not. There are all kinds of non-standard things that can
be done with a kml/kmz.
Best wishes.
On Wed, Jul 14, 2021 at 8:37 AM krishna Ayyala <ayyalakrishna at gmail.com>
wrote:
> I have used the Import KML/KMZ  tool. Tried to save it as a polygon
> shapefile. It did not produce any polygon. After running the tool, it gave
> a message "0 polygons extracted".
> Regards.
> On Wed, Jul 14, 2021 at 4:50 AM C Hamilton <adenaculture at gmail.com> wrote:
>> You can use the KML Tools plugin.
>> Sent from my iPod
>> > On Jul 14, 2021, at 5:27 AM, Stefan Giese (WhereGroup) <
>> stefan.giese at wheregroup.com> wrote:
>> > This is a multi-part message in MIME format.
>> > --------------E04465FB052329DF442E16B9
>> > Content-Type: text/plain; charset=utf-8; format=flowed
>> > Content-Transfer-Encoding: quoted-printable
>> > unfortunally I didn't read the whole feature description in the=20
>> > changelog, it says=C2=A0 "...Currently only supports line symbol
>> conversi=
>> > on,=20
>> > but point and polygon symbol support is under development...." may be=20
>> > that is the reason...
>> >> Am 14.07.2021 um 11:21 schrieb krishna Ayyala:
>> >> Stefan,
>> >> Thanks a lot for your reply. I have upgraded my QGIS version to 3.20=20
>> >> and added the kmz file on to my map. Still I am getting the plain=20
>> >> rectangle. I am not getting the symbology as it is in the o
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210714/a1a295f0/attachment.html>
