[Qgis-user] Problem using Model Inputs variable in an Select by expression in the model Designer
Charles Dixon-Paver charles at kartoza.com
Tue Jul 20 02:53:16 PDT 2021
Hi Nicholas,
I haven't had time to dig into this extensively or encountered this
particular issue, but I would suggest trying to "force" the expression to
retrieve the correct info regardless of context using something like this:
with_variable('Length2',  to_string(@NamelengthField) || '2',
if(attribute(to_string(@NamelengthField)) != attribute(@Length2), TRUE,
FALSE))
That's probably an extreme example but hopefully it illustrates my point.
If you want to share a sample dataset/ model I can try to have a look at
how to resolve it.
Regards
On Tue, 20 Jul 2021 at 10:46, Richard McDonnell <richard.mcdonnell at opw.ie>
wrote:
> Nicolas,
> I have not looked at this in too much detail, but at a quick glance, could
> it not be the fact that you should be using the newly created fields? As in
> instead of *@NamelengthField != @NamelengthField || '2'*, should it not
> be more like your previous example *Length != Length2*
> Regards,
> Richard
> Richard McDonnell MSc GIS, FME Certified Professional
> *FRM Data Management*
> Oifig na nOibreacha Poiblí
> Office of Public Works
> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
> Jonathan Swift Street, Trim, Co Meath, C15 NX36
> M +353 87 688 5964 T +353 46 942 2409
> https://gov.ie/opw
> To send me files larger than 30MB, please use the link below
> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
> Email Disclaimer:
> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Nicolas
> Cadieux
> *Sent:* 20 July 2021 09:27
> *To:* Qgis Users List <qgis-user at lists.osgeo.org>
> *Subject:* Re: [Qgis-user] Problem using Model Inputs variable in an
> Hi,
> Does anyone have an idea?
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 8 juill. 2021 à 01:17, Nicolas Cadieux <njacadieux.gitlab at gmail.com> a
> écrit :
> Hi,
> I am creating a model that fixes Network files before they are used in the
> QGIS Network analysis (Shortest path) tools.
> This is my work flow:
>    1. Create a "Length" field (value) and calculate $length in the field
>    calculator
>    2. Split the Multipart lines into Singlepart lines
>    3. Create a "Length*2*" field (value) and calculate $length in the
>    field calculator
>    4. Select by expression Length != Length2.  This basically gives me a
>    selection of line that have been modified by the Multipart to Singlepart
>    algorithm. (I get 8 results)
> This works well
> The problem is when I create and Input String to let the user create a
> "Length" field.  This become a variable called @NamelengthField. My work
> flow become:
>    1. User input "Length" in the Model input. (@NamelengthField)
>    2. Create a "Length" field using  @NamelengthField (as pre-calculated
>    value) and calculate $length in the field calculator: This is OK
>    3. Split the Multipart lines into Singlepart lines: This is OK
>    4. Create a "Length2" field using  @NamelengthField ||'2'  (as
>    pre-calculated value) and calculate $length in the field calculator: This
>    is OK this field (Length2) is created and calculated properly.
>    5. I get stuck  when I try Select by expression using
>    @NamelengthField != @NamelengthField || '2' (as pre-calculated value) (I
>    get all lines back) and the test does not work.
> I tried stuff like
> @NamelengthField != (@NamelengthField || '2')
> '@NamelengthField != @NamelengthField || '2''
> "@NamelengthField != @NamelengthField || '2'"
> "@NamelengthField"|| !=|| "@NamelengthField || '2'"
> Even simple @NamelengthField = 5.286365157529550 (which should extract
> exactly one value).
> Any ideas?
> Nicolas
> QGIS 3.18.2 on Windows 10
> Nicolas Cadieux
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210720/66c95da8/attachment.html>
