[Qgis-user] Symbology using an expression to find a field with known suffix
Delaz J delazj at gmail.com
Wed Jul 21 01:00:25 PDT 2021
Hi Andrew,
Try something like
  eval(
   array_to_string(
    array_filter(
     map_akeys(attributes()),
     right(@element, 5) = '_blah')
You may want to read the help of each involved function to better
understand how things work here.
HTH,
Harrissou
Le 21/07/2021 à 02:36, Andrew Hughes a écrit :
> Hi All,
> Any help would be much appreciated,  sorry for just throwing this out
> there... QGIS is very new to me.
> I have lots of tables that I would like to apply common symbology and
> best I explain with an example:
> table_a.foo_blah
> table_b.boo_blah
> table_c.whatever_blah
> table_d.i_cant_believe_its_not_butter_blah
> Q: What would the expression be to find the field ending with "_blah"
> and use/return that fields value (as the symbology's categorical
> value)? I will never know what the field is called, just that it
> always ends in _blah.
> Big thanks in advance,
> Andrew
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210721/476b5052/attachment.html>
