[Qgis-user] QGIS Select by Location, but no within a distance of
Nicolas Cadieux njacadieux.gitlab at gmail.com
Tue Mar 2 11:37:12 PST 2021
The easiest way to implement would be to use the graphical modeler.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 2 mars 2021 à 13:59, C Hamilton <adenaculture at gmail.com> a écrit :
> I just had a user tell me he had to go back to ArcGIS so that he could use the Select by Location function and specify a distance from the feature. He could not believe that it was not available in QGIS. See
> https://desktop.arcgis.com/en/arcmap/10.3/map/working-with-layers/using-select-by-location.htm
> What he is looking for is the "Are within a distance of" operator. Am I missing it in QGIS if not this is a really important operator to include. I know you can always prebuffer the layer, but for an analyst who does this regularly ours will go back to using ArcGIS.
> Would this be fairly easy to implement?
> Calvin
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210302/8fa105a7/attachment.html>
