[Qgis-user] noobs -- question
Marc Millas marc.millas at mokadb.com
Sun Mar 7 13:51:04 PST 2021
I may be missing something more than obvious, but ...
QGIS 3.16 on win 10, postgres 12 with postgis 3.1 (same, machine (intel
core i9, 64 GB ram, 6TB SSD))
a postgis table with a column geography(multipolygon, 4326)
-no pb to display this as a layer over whatever map (OSM standard as an
exemple).
-no pb in qgis to go to edition mode, and add a few new polygons, edit the
table fields and save. fine.
When I want to edit (ie. change..) one of the existing polygons, I:
--ask to go to edit mode with right click on that postgis layer
--select one of the existing polygons, (after choosing the select entity
icon)
--??? according to the doc, I should click on the edit node icon. Which is
grayed.
the qgis postgres user have all rights to write (proof by the inserts done)
So.. there is something obvious somewhere, but I need some help to guess
where :-)
thanks for your help,
regards,
Marc MILLAS
Senior Architect
+33607850334
www.mokadb.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210307/11ca8f42/attachment.html>
