[Qgis-user] noobs -- question
Marc Millas marc.millas at mokadb.com
Sun Mar 7 16:57:53 PST 2021
create table bidule (id serial, libelle text, geog geography(multipolygon,
4326));
as simple as possible :-)
thanks for your help !
Marc MILLAS
Senior Architect
+33607850334
www.mokadb.com
On Mon, Mar 8, 2021 at 1:25 AM Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hello Marc,
> Can you share your table SQL definition?
> My gut feeling is that you might not have a unique identifier column.
> Alexandre Neto
> QGIS Support
> www.cooperative.net
> On Sun, Mar 7, 2021 at 9:51 PM Marc Millas <marc.millas at mokadb.com> wrote:
>> Hi,
>> I may be missing something more than obvious, but ...
>> QGIS 3.16 on win 10, postgres 12 with postgis 3.1 (same, machine (intel
>> core i9, 64 GB ram, 6TB SSD))
>> a postgis table with a column geography(multipolygon, 4326)
>> -no pb to display this as a layer over whatever map (OSM standard as an
>> exemple).
>> -no pb in qgis to go to edition mode, and add a few new polygons, edit
>> the table fields and save. fine.
>> When I want to edit (ie. change..) one of the existing polygons, I:
>> --ask to go to edit mode with right click on that postgis layer
>> --select one of the existing polygons, (after choosing the select entity
>> icon)
>> --??? according to the doc, I should click on the edit node icon. Which
>> is grayed.
>> the qgis postgres user have all rights to write (proof by the inserts
>> done)
>> So.. there is something obvious somewhere, but I need some help to guess
>> where :-)
>> thanks for your help,
>> regards,
>> Marc MILLAS
>> Senior Architect
>> +33607850334
>> www.mokadb.com
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210308/6c56abc4/attachment.html>
