[Qgis-user] Create circle with diameter in QGIS
Andreas Neumann a.neumann at carto.net
Fri Mar 12 05:08:48 PST 2021
Hi Madeline,
You need to enable the "Advanced Digitizing mode/panel". See
https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#the-advanced-digitizing-panel
for details.
The shortcut "d" (distance) is your friend. When this mode is activated
you can enter distances (like your radius) with the keyboard and QGIS
will constrain to these values.
You need to invest a bit of time to understand all the construction
modes, but once you get it, it is quite powerful.
Greetings,
Andreas
On 2021-03-12 13:37, Madeline Krohn wrote:
> Dear QGIS Team,
> I would like to create a circle whose diameter is 75 metres. I am using
> QGIS version 3.16.3-Hannover.
> My procedure so far has been like this:
> 1. create a new shapefile layer -> geometry type: polygon
> 2. in edit mode of this layer: add circle with centre and another point
> --> How can I change the radius/diameter of the circle afterwards or is
> there another possibility to create a circle with diameter directly?
> Thank you very much and best regards
> Madeline
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210312/bf89f634/attachment.html>
