[Qgis-user] Selecting profiles
Charles Dixon-Paver charles at kartoza.com
Thu Mar 18 02:24:09 PDT 2021
Creating a custom shortcut/ launcher is also the only way I can think of.
There was a related thread on this previously in which various possible
solutions using python, bash scripts or windows batchfiles were provided,
which may be useful for your needs.
http://osgeo-org.1560.x6.nabble.com/Have-QGIS-prompt-for-profile-to-use-everytime-td5448226.html
User profiles are usually stored in the user/ appdata directory on the OS
though, so you can also manage access permissions/ profiles through that
depending on your environment setup.
On Thu, 18 Mar 2021 at 03:40, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hi Ed,
> The only way I think of is by creating a shortcut that launches QGIS using
> the command line tools. Using this, you can specify which profile to use
> and which project:
> https://docs.qgis.org/3.16/en/docs/user_manual/introduction/qgis_configuration.html#command-line-and-environment-variables
> Best regards,
> Alexandre Neto
> QGIS Support
> www.cooperative.net
> On Wed, Mar 17, 2021 at 10:44 PM Ed Hawkins <elh1964 at gmail.com> wrote:
>> I have created 4 profiles a reader qith no editing capabilities and 3
>> editors. I want to force someone opening a project to select a
>> user profile. Is that possible and if so how?
>> Ed Hawkins
>> Henderso County E911
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210318/84656d97/attachment.html>
