[Qgis-user] Map styles changing when I export as image
David Greenewalt dlg at sover.net
Sun Mar 21 06:11:22 PDT 2021
Jeremy,
What version of QGIS are you using?  It may be entirely unrelated, but I
ran into serious problems exporting map layouts to PDF.  I noticed it at
3.18 (Windows 10).  Some, not all, exports were using a lot of memory,
and it would actually cause one of my duel screens to go blank and stop
working.  Apparently I had too little RAM (8 gigs) - I added 16 more and
all is working fine now.  It took a long time to resolve as I was
looking at software and settings and it was actually my hardware/system
being overwhelmed.  Just a thought.
David
On 3/21/2021 4:47 AM, jeremy benwell wrote:
> Hi all,
> I'm having some trouble with exporting my map as an image. When I try
> to export my map as an image all the styles change (see images below,
> I had to shrink size to make email within 100kb limit so they are a
> bit blurry). The dpi I choose is 100. I'm guessing the problem has
> something to do with what layers are selected in the project tab but
> can't seem to figure out how exactly. Is there some way to stop the
> project tab from feeding information to the print layout tab so i can
> export the print layout tab as an image exactly as is.
> Any help would be much appreciated.
> Cheers,
> Jeremy
> How I want my map to be exported as an image
> My project layers
> How my map is actually exported as an image
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210321/971bbf8f/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210321/971bbf8f/attachment-0003.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210321/971bbf8f/attachment-0004.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210321/971bbf8f/attachment-0005.jpg>
