[Qgis-user] First steps with 3D Scan Data?
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Fri Mar 26 01:34:55 PDT 2021
Hi Benoit,
ok, thanks. las then.
But when I read about the lastools plugin, the description says that I
need to install the lastools software, and the website there tells me
that the license is about 1500€ which is a little too much for some
learning efforts.
Any other options?
Cheers,
Bernd
On 26.03.21 09:28, Benoit de Cabissole wrote:
> Hi Bernd,
> OK, that more info!
> The files are likely to be in Timble RealWorks format.
> So you will have to get your contractor to provide you with .las files,
> otherwise your stuck buying RealWorks!
> Or, perhaps, the viewer is able to export in .las??
> When you get las files, you can use lastools plugin for QGIS to
> process them.
> Cheers,
> Benoit
> On 26/03/2021 10:01, Bernd Vogelgesang wrote:
>> Hi Benoit,
>> as I was not present when the scans were made, I can only assume that
>> this was a laser scanner on a tripod.
>> With the sent data, there is a Trimble Scan Explorer Viewer software
>> where I can make a "virtual walk" through the scene, so there have to be
>> photos but also laser scan data as I can see from different view modes.
>> As I said, this is the very first time I get in touch with this stuff,
>> and Google was of no big help so far.
>> Besides of tons of other files, the bigger ones with around 50 to 80 MB
>> are .rwcx and .tzf files.
>> I hoped that someone would know what these file explicitly hold, and
>> what I have to do to get them e.g. into QGIS or other open source
>> software.
>> Cheers,
>> Bernd
>> On 26.03.21 08:40, info wrote:
>>> Hi Bernd,
>>> Well, could you give more info? E.g. what kind of scan:
>>> laser/lidar/photo/other? This will influence your workflow.
>>> +/-Open source laser/lidar could be based on lastools [1]
>>> Open source photogrammetry could be based on AliceVision meshroom
>>> [2,3],  MeshLab [4] and blender [5]
>>> In photogrammetry: Agisoft metashape [6] and pix4D [7] as good
>>> commercial products.
>>> BTW: 32 scans, if photos, is quite a very low number of photos for
>>> reconstructing a 3D scene!
>>> Hope this helps.
>>> Cheers,
>>> Benoit de Cabissole
>>> [1] http://lastools.org/
>>> [2] https://alicevision.org/#photogrammetry
>>> [3] https://github.com/alicevision/meshroom
>>> [4] https://www.meshlab.net/
>>> [5] https://www.blender.org/
>>> [6] https://www.agisoft.com/
>>> [7] https://www.pix4d.com/
>>> On 25/03/2021 23:07, Bernd Vogelgesang wrote:
>>>> Hi folks,
>>>> in a project on a former dumpside now to be transformed into a sand
>>>> lizard habitat, I saw the chance to get my hands dirty for the first
>>>> time on 3D scan data (terrestrial). I received 10GB of stuff, and now
>>>> I'm completely lost.
>>>> The data consists of .rwcx files, .tzf files and lots of other stuff.
>>>> Is there any chance that I can process any of this data with an open
>>>> source stack?
>>>> Or what should be done, to make them digestible?
>>>> Second step: There seem to be 32 different scans of the area form all
>>>> angles. In case I succeed to somehow load the data, how do I combine
>>>> them ?
>>>> For the first steps, I actually "only" would like to generate a decent
>>>> DEM from the data to be able to place some features on a map for the
>>>> guys in charge to do the habitat stuff.
>>>> Any kind of hints or links to reads about this topic would be
>>>> appreciated
>>>> Cheers,
>>>> Bernd
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
