[Qgis-user] convex and concave areas
Sebastian Gutwein
bas at rdgland.com
Wed May 5 06:30:39 PDT 2021
In the QGIS toolbox there is a Saga algorithm called Terrain Surface
Convexity that does calculate convexity or concavity. I have never used it.
http://www.saga-gis.org/saga_tool_doc/2.2.3/ta_morphometry_21.html
https://sourceforge.net/p/saga-gis/discussion/354013/thread/3fadd3e7/
On Wed, May 5, 2021 at 4:14 AM Stefan Giese (WhereGroup) <
stefan.giese at wheregroup.com> wrote:
> one process could be:
> - smooth the DTM by a neigbourhood analysis. The width depends on the
> size of your convex and concave areas. you can use a mean filter or lowpass
> for example
> - substract the filtered from the original
> - select values > or < your cutoff
> - convert this into polygons
> see
> https://www.researchgate.net/profile/Hazen-Russell/publication/277324326_A_semi-automated_esker_detection_method_EDM_for_improved_quantification_of_glaciated_landscapes/links/5567b6ca08aeab77721eac23/A-semi-automated-esker-detection-method-EDM-for-improved-quantification-of-glaciated-landscapes.pdf
> for further reading
> Hope this helps
> Stefan
> Am 05.05.2021 um 10:02 schrieb Azzurra Lentini:
> Hi list,
> I need to find the convex and concave areas from a dtm raster file. Do you
> have any suggestions?
> Thanks
> Adjunct Professor University "Roma Tre"
> Gis Applied for Environmental studies
> Risk modelling & Hydrogeology
> Consultant DFID-UK, United Nations, EU projects
> AZZURRA LENTINI
> Italy Mobile Tel.: **(39) 338 24 40 676
> SKYPE azzurrahydro
> *azzurralentini at gmail.com <azzurralentini at gmail.com>*
> *azzurra.lentini at uniroma3.it <azzurra.lentini at uniroma3.it> *
> *Par respect pour l'environnement,*
> *n'imprimez ce mail qu'en cas d'absolue nécessité*
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Fon: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> stefan.giese at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210505/af47236a/attachment.html>
