[Qgis-user] NDVI resolution
Neels Brink
Neels.Brink at incomargroup.com
Fri May 7 11:27:39 PDT 2021
Yes, the raster calculator, and the extent (resolution, nr of pixels, everything) of the output file matches that of the two input bands. What is interesting is that I noted that the boundaries of some man-made objects do no show this fuzziness:
[cid:image006.jpg at 01D7437F.67F906C0]
From: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
Sent: Friday, May 7, 2021 6:27 PM
To: Neels Brink <Neels.Brink at incomargroup.com>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] NDVI resolution
Did you use the raster calculator? If so, did you select the proper extent and rows and columns in the output files?
https://docs.qgis.org/3.16/en/docs/user_manual/working_with_raster/raster_analysis.html#raster-calculator
Nicolas Cadieux
https://gitlab.com/njacadieux
Le 7 mai 2021 à 11:56, Neels Brink <Neels.Brink at incomargroup.com<mailto:Neels.Brink at incomargroup.com>> a écrit :
I created an NDVI in QGis from Worldview -3 bands. However, the NDVI looks ‘fuzzy’, or at lower resolution than the original bands. I tried to find a flag or setting which causes this but do not see something like it. What could be the reason for this appearance of the NDVI?
<image001.jpg>
<image002.jpg>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210507/8ab18b22/attachment.html>
Type: image/jpeg
Desc: image006.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210507/8ab18b22/attachment.jpg>
