[Qgis-user] SPLIT POLYGONS INTO 3 PARTS
Andrea Giudiceandrea
andreaerdna at libero.it
Wed May 19 09:29:17 PDT 2021
thayeray wrote
> To add to what Nicolas wrote. In case you use PostGIS, there is a
> procedure ST_Segmentize http://postgis.net/docs/ST_Segmentize.html that
> does this in one step for polygons
Hi Thayer,
AFAIK PostGIS ST_Segmentize only works on lines and on perimeter of polygons
and doesn't split polygons in equal area.
Could you please give more info about the possibility to use ST_Segmentize
to split polygons in equal areas?
Regards.
Andrea
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
