[Qgis-user] Print composer issue - QGis 3.22.00
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Tue Nov 16 16:00:49 PST 2021
Have you both been using wms server data, or other online data in your maps?
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 16 nov. 2021 à 13:35, Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz> a écrit :
> Hi Sebastien
> I reported this bug back in 3.20 (July)
> https://github.com/qgis/QGIS/issues/44426
> To date, I have had no feedback as to confirmation of a bug or because of my doing, so in a way it is good to hear of a similar problem from another user.
> While not a show stopper, it is extremely annoying and seems to be a worse problem in 3.22 than it was in 3.20. By that I mean the misalignment seems worse. In V3.20 zooming the layout to 100% seemed to fix the screen misalignment, in 3.22 it does not.
> Questions:
> Are you using label masks? If you disable them does your problem disappear?
> Even though the display is not aligned, does printing or exporting an image produce correctly aligned output?
> Cheers
> Tony
> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of CCM-S.RAYOT
> Sent: Tuesday, 16 November 2021 11:02 pm
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Print composer issue - QGis 3.22.00
> Hi,
> i,ve got a problem with raster layers on the print composer: there is a mismatch between raster layers and vector layers. i've checked the CRS, all seems to be normal.
> Help!
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211116/1a4a4939/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211116/1a4a4939/attachment-0001.png>
