[Qgis-user] Profile tool doesn't work on my MacBook Pro?
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Fri Sep 3 07:52:59 PDT 2021
I can confirm on the other project (crayfish) the same problem related
to pyqtgrapth (both 0.11 and 0.12 versions) with EXC_CRASH (SIGABRT) in
PyEval_SaveThread. I am investigating it, but it wouldn't be easy to
debug....
P.
On Fri, Sep 3, 2021 at 1:19 PM Peter Petrik <
peter.petrik at lutraconsulting.co.uk> wrote:
> Hi, with shut down you mean it crashes? If yes, does it produce a crash
> stack trace?
> Peter
> On Fri, Sep 3, 2021 at 1:16 PM Nicolas Cadieux <
> njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> I don’t know what is going on. I would create a new user profile and try
>> again. You could directly contact the programmers. You should find the
>> info on the plugin page. https://plugins.qgis.org/plugins/profiletool/
>> Nicolas Cadieux
>> https://gitlab.com/njacadieux
>> Le 3 sept. 2021 à 07:01, Joyce Hoed <j.hoed at icloud.com> a écrit :
>> Hello,
>> Can anyone help me out. I am a new user of QGIS and I want to use the
>> profile tool for civil work purposes. I installed the latest version of
>> QGIS on my MacBook Pro (specs below):
>> 2,3 GHz 8-Core Intel Core i9
>> 16 GB 2400 MHz DDR4
>> Radeon Pro 560X 4 GB
>> Qgis works, but every time I try to use the profile tools the program
>> automatically shuts down? I try tho install en re-install the plug in but
>> it doesn’t make any difference. Can someone help me out with this problem?
>> Kind regards,
>> Joyce
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210903/21a65424/attachment-0001.html>
