[Qgis-user] QGIS.org Mac DL Links failing?
Mr. Stace D Maples
stacemaples at stanford.edu
Fri Sep 10 09:57:03 PDT 2021
So, I’ve cleared caches, tried in private mode, and tried 2 different (private) VPNs, too. My colleague, next door, can’t DL the MacOS versions, either.
We are both able to DL the Windows versions.
Here’s an oddity: I am able to DL the file, using Brave, in Private/Tor mode. Or, at least, it has started downloading. I’ll let you know if it completes, and is valid. It will be a while, Tor is SLOOOOOOOOOW.
(Please note that my laptop inserts random double keystrokes. Sometimes, I just can’t repair all of it.)
In F,L&T,
Stace Maples
Assistant Director of Geospatial Collections & Services
Stanford Geospatial Center & Branner Earth Sciences Library Map Collection
Get GeoHelp: https://stanford-geospatial.slack.com/
Find GeoData: https://earthworks.stanford.edu<https://earthworks.stanford.edu/>
stanfordgis Listserv: https://mailman.stanford.edu/mailman/listinfo/stanfordgis
Listen to Stanford’s KZSU Zootopia RoboDJ: http://kzsu.rocks<http://kzsu.rocks/>
_____
.'-;_,; ':-;_,'.
/; '/ , _`.-\
|:. `\`-. \_ / |
`'-._____.-'
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of Richard Duivenvoorde <rdmailings at duif.net>
Date: Thursday, September 9, 2021 at 11:50 PM
To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] QGIS.org Mac DL Links failing?
On 9/10/21 8:41 AM, Jürgen E. Fischer wrote:
> On Thu, 09. Sep 2021 at 17:26:56 +0000, Mr. Stace D Maples wrote:
>> Anyone else getting Failed No File errors on the DL links for the Mac PR and LTR? I’m getting this in Brave, Firefox and Chrome.
>> [cid:image001.png at 01D7A565.365BE130]
>> Any other place to get them, other than the following?:
>> https://qgis.org/downloads/macos/
> Hm, sounds like https://github.com/qgis/QGIS-Website/issues/935
> No sure what it is - the files were apparently ok.
Recently I was in an environment where they had a so called 'netscaler' (as outgoing proxy I think) to 'clean and guard' downloads from the internal office.
With me that meant:
- using pip: 95% of packages went ok, but some of them triggered something on the netscaler, making it abort the download
- same with npm runs
- same with some installers or zips/jars...
So: could it be that there is 'something' in between the connections between QGIS and this mac's?
In cases of failure, moving to another (4G or another physical) connection, does that help?
Regards,
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210910/0777e970/attachment.html>
