[Qgis-user] WMS with filter function
Andrea Peri
aperi2007 at gmail.com
Sat Sep 11 01:13:06 PDT 2021
Hi, I guess an important reason because is not easy the develope what you
need is that the filter section is not standardized in the wms 1.3.0 specs.
A.
Il sab 11 set 2021, 10:06 Bo Victor Thomsen <bo.victor.thomsen at gmail.com>
ha scritto:
> Hi list -
> There might be an obvious answers to these questions, but anyway:
> Is there a method to apply a filter definition to a WMS layer in the QGIS
> Data-Manager WMS section - without writing it directly into the HTTP
> address of the WMS server, i.e *not* like this: http://*..url..*&FILTER=*...XML
> mess..* ?
> And the second question: Is there any function / plugin to "humanize" a
> WMS filter definition, i.e defining the filter by *not* using XML and
> having the function to translate it to XML ??
> I am aware of GeoServer's CQL_FILTER parameter. However the WMS server in
> question is not GeoServer.
> I had a look at the most obvious place for a filter definition: The
> properties of a WMS layer, section "Source" and a possible "Provider
> Feature Filter" textbox, but alas: No luck finding it.
> (I might be totally of the rail by expecting that you can apply a filter
> to a WMS service. In that case, please inform me :-)
> Med venlig hilsen / Kind regards
> Bo Victor Thomsen
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210911/a54c5e5d/attachment.html>
