[Qgis-user] datum transformation in qgis server
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Sep 24 00:31:10 PDT 2021
Hi all,
we recently hit a problem, that QGIS server, when serving GeoJSON data
via WFS, is not using correct datum transformation parameters.
1. Original data (EPSG:5514
+towgs84=572.213,85.334,461.94,-4.9732,-1.529,-5.2484,3.5378)
2. QGIS Server GeoJSON over WFS -> automatic translation to WGS84
result is, that the GeoJSON data are shifted about 40m (which is
common problem, if the data are transformed without +towgs84)
In QGIS Server 2.18, there was DEFAULT_DATUM_TRANSFORM environment
variable [1] but this seems to be missing in current QGIS version [2]
How to force QGIS Server 3.x to use datum transformation options?
Thanks
Jáchym
[1] https://docs.qgis.org/2.18/en/docs/user_manual/working_with_ogc/server/config.html#environment-variables
[2] https://docs.qgis.org/testing/en/docs/server_manual/config.html#environment-variables
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
