[Qgis-user] Transform vectordata using affine transformation
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Sat Sep 25 09:48:54 PDT 2021
Hi list -
One of my customers just received a data file, where the coordinates is
not in any projection: Center of map data is (0,0), units in mm. not
meter, maybe some rotation too. However, at least it's a planar
coordinate system (I hope).
Instead of sending the #¤%&! data file back to the "GIS no-good"
architect who send it , I've decided to - once and for all - to find a
method to transform this kind of data to a reasonable CRS using an
affine transformation.
* I'm aware of the Processing algorithm "Affine transform" that can do
the actual transformation once I know the translation, rotation and
scale coefficients of the transformation.
* And I know how to find the affine transformation matrix using a set
of points from the data that corresponds with a set of points in the
destination CRS.
However, Is there any plug-in that can:
1. Digitize a set of positions from the original data.
2. Digitize or manually set the corresponding positions in the
destination CRS
3. Create the translation, scale and rotation parameters using data
from (2)
4. Run the "Affine transformation" algorithm to transform the data to
the right position in the chosen CRS
In short - a Georeferencer for vector data
* A name of a functioning plug-in would be lovely
* A set QGIS classes/methods that could help with establishing the
transformation matrix and other stuff would be really nice
* A "No" to all my wishes would suck. However, In that case, I can
start developing without have the nagging feeling that someone has
done this before
Med venlig hilsen / Kind regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210925/587b631e/attachment.html>
