[Qgis-user] Info click with geometry generator
Paul Wittle
paul.wittle at dorsetcouncil.gov.uk
Thu Sep 30 00:14:54 PDT 2021
I've added a geometry generator to a line feature layer to buffer the line by 150m. This works fine in terms of the way it is displayed but when you info click on the buffered area it does not return any results.
Is there a way to make the info click query based on the full extent of the styling rather than just the feature itself?
This would be the same as what happens when you use WMS GetFeatureInfo; in that situation the infoclick is based on the rendered result rather than just the underlying data.
Any hints would be appreciated.
Thanks,
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/data-protection
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210930/69bca9d8/attachment.html>
