[Qgis-user] Error when zooming to xyz tile layer at zoom level 23
Marcus Grätsch
marcus.graetsch at kernblick.de
Fri Apr 1 06:03:04 PDT 2022
Hello,
I also created an issue on Github on following error, maybe someone here has an idea how to solve this..
We are using XYZ Tiles in PNG Format and zoom levels 10 to 23.
When we zoom in down to 23, we get an error when QGIS should display level 23, the error message is pasted in below.
As you see the algorithm tries to pick an image named: "23/0/0.png". 23 is the folder name for zoom level. In zoom levels 10 to 22 the following zeros always contain higher numbers (according to x y poitions) but here the automatically generated name/path seems not to work.
{ "Bytes Received": 258, "Bytes Total": 258, "Cache (control)": "Load from cache if available, otherwise load from network", "Cache (save)": "Can store result in cache", "Headers": { "Accept": "*/*", "User-Agent": "Mozilla/5.0 QGIS/32204" }, "ID": "src/providers/wms/qgswmsprovider.cpp:4217 (QgsWmsTiledImageDownloadHandler)", "Initiator": "QgsWmsTiledImageDownloadHandler", "Operation": "GET", "Replies": 1, "Reply": { "Cache (result)": "Read from network", "Error": "Error transferring URL_DOMAIN_NAME/path/20220311_Gesamtareal/23/0/0.png - server replied: Not Found", "Error Code": "203", "Headers": { "Connection": "keep-alive", "Content-Length": "258", "Content-Type": "application/xml;charset=utf-8", "Date": "Thu, 31 Mar 2022 13:08:31 GMT", "Server": "nginx/1.21.5", "X-Frontend": "fes300335" }, "Status": "404" }, "Thread": "0x000060000140a970", "Total time (ms)": 61, "URL": "URL_DOMAIN_NAME/path/20220311_Gesamtareal/23/0/0.png" },
Thank you for your time,
Marcus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220401/e069f9c9/attachment.html>
