[Qgis-user] Snap existing geometry to other layer
Germán Carrillo
carrillo.german at gmail.com
Fri Apr 8 08:13:06 PDT 2022
also make sure you use QGIS 3.22.x or above, since the algorithm "Snap
Geometries to Layer" has been optimized just before that version.
Details at:
https://github.com/qgis/QGIS/pull/42781
https://github.com/qgis/QGIS/pull/44766
Regards,
Germán
El vie, 8 abr 2022 a las 9:55, Nicolas Cadieux via Qgis-user (<
qgis-user at lists.osgeo.org>) escribió:
> Backup backup backup!
> The snap geometries to layer works very well as Alexandre stated.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 8 avr. 2022 à 07:12, Alexandre Neto via Qgis-user <
> qgis-user at lists.osgeo.org> a écrit :
> Hi Uwe,
> The snap geometries to layer tool in processing toolbox can be used in
> in-place feature editing, which does the changes without creating a new
> layer.
> https://docs.qgis.org/3.22/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#snap-geometries-to-layer
> https://docs.qgis.org/3.22/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html?highlight=place#the-processing-in-place-layer-modifier
> Best regards
> Alexandre Neto
> User support
> www.qcooperative.net
> Uwe Fischer via Qgis-user <qgis-user at lists.osgeo.org> escreveu no dia
> sexta, 8/04/2022 à(s) 11:34:
>> Hello,
>> I need to snap individual features to another layer. It’s not new
>> features but existing ones. And, the process should not create a new
>> shapefile but it should modify existing features that were selected
>> beforehand for snapping.
>> Google told me that there is a Plugin called „Geometry Snapper“ but I
>> could not find in for QGIS 3.22 LRT.
>> Any ideas? Thank you so much!
>> Regards, Uwe
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
|\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
https://twitter.com/GeoTux2 <http://twitter.com/GeoTux2>
<http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220408/fe51ce74/attachment.html>
