[Qgis-user] Activating ESRI geodatabase (.gdb) write mode in QGIS, OGR2OGR or Python
Nicolas Cadieux njacadieux.gitlab at gmail.com
Wed Apr 20 18:10:11 PDT 2022
I am in a bit of a bind.  I am basically trying to figure out a way to
write some .shp file to a .gbd folder using the gbd drivers obtained
from ESRI. I am not sure what file to copy and where.  I am tying to
make this work with ogr2ogr at the dos command prompt but getting to
work with a anaconda python environment would be nice.
Can the ESRI File Geodatabase API also be used write to a .gdb file
using QGIS?
If you recently did this, I would appreciate some tips.
I am on windows 10 using the OSGEO4W install with QGIS 3.24.
https://gdal.org/drivers/vector/filegdb.html
Thanks
Nicolas Cadieux
https://gitlab.com/njacadieux
