[Qgis-user] Activating ESRI geodatabase (.gdb) write mode in QGIS, OGR2OGR or Python
Mike Treglia
mtreglia at gmail.com
Thu Apr 21 06:42:38 PDT 2022
That's correct in my experience. In the OSGeo4W installer, go through the
advanced install menu, and when you get the options for libraries, I think
searching for gdb should bring up the right one - then check the box and
proceed.
On Wed, Apr 20, 2022 at 11:22 PM Saulteau Don via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> I think in the osgeo4w installer you just have to install the gdal-filegdb
> package for that driver.
> Donovan
> On Wed., Apr. 20, 2022, 18:11 Nicolas Cadieux via Qgis-user, <
>> Hi,
>> I am in a bit of a bind. I am basically trying to figure out a way to
>> write some .shp file to a .gbd folder using the gbd drivers obtained
>> from ESRI. I am not sure what file to copy and where. I am tying to
>> make this work with ogr2ogr at the dos command prompt but getting to
>> work with a anaconda python environment would be nice.
>> Can the ESRI File Geodatabase API also be used write to a .gdb file
>> using QGIS?
>> If you recently did this, I would appreciate some tips.
>> I am on windows 10 using the OSGEO4W install with QGIS 3.24.
>> https://gdal.org/drivers/vector/filegdb.html
>> Thanks
>> Nicolas Cadieux
>> https://gitlab.com/njacadieux
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220421/2d02d748/attachment.html>
