[Qgis-user] Insert Logo into the map composer
krishna Ayyala
ayyalakrishna at gmail.com
Mon Apr 25 10:34:39 PDT 2022
Alexandre,
That worked. Thank you for your help.
Regards.
On Sun, Apr 24, 2022 at 1:52 AM Alexandre Neto <senhor.neto at gmail.com>
wrote:
> Hi,
> If I am not wrong, I think you can simply drag and drop the jpeg file into
> the layout.
> Give it a try.
> Alexandre Neto
> User support
> www.qcooperative.net
> A sábado, 23/04/2022, 22:04, Nicolas Cadieux via Qgis-user <
> qgis-user at lists.osgeo.org> escreveu:
>> Select raster image
>> On 2022-04-23 2:52 p.m., krishna Ayyala wrote:
>> Thank you. But that popup window is not allowing me to navigate to any
>> jpeg file. only option it has is svg image.
>> Regards.
>> On Fri, Apr 22, 2022 at 9:35 AM Nicolas Cadieux <
>> njacadieux.gitlab at gmail.com> wrote:
>>> Hi,
>>> https://docs.qgis.org/3.22/en/docs/training_manual/map_composer/map_composer.html
>>> You will see an Icon on the left (blue sky with a mountain). Or Add
>>> Item/add picture.
>>> Nicolas
>>> On 2022-04-22 9:05 a.m., krishna Ayyala via Qgis-user wrote:
>>> > Hello,
>>> > I have a map in the map composer. How can I insert a logo which is a
>>> > jpeg image into the map composer?
>>> > Regards.
>>> > _______________________________________________
>>> > Qgis-user mailing list
>>> > Qgis-user at lists.osgeo.org
>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Nicolas Cadieux
>>> https://gitlab.com/njacadieux
>> Nicolas Cadieuxhttps://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220425/62b96dba/attachment.html>
