[Qgis-user] Keypress event and slowless
Sebastian Gutwein bas at rdgland.com
Wed Aug 3 07:29:22 PDT 2022
I have been experiencing the same problem. It seems to occur when there are
a lot of elements in the map. Very painful experience. And I agree that it
seems like it shouldn't need to be calculating while you are typing.
On Wed, Aug 3, 2022 at 7:33 AM Jésahel Benoist via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Hi,
> On Windows/QGIS 3.16/QGIS 3.22 LTR, am I the only one having noticed some
> annoying slowness in big projects when typing ? It happens especially in
> layout when changing a legend element name or in the attribute table.
> What is really annoying is that each keypress seems to trigger some heavy
> calculation. I think it should only happen when exiting the field, or maybe
> to be able to know what events are triggered to try to correct this,
> because it could be a plugin or a calculated field or anything.
> Regards,
> Jésahel
> Qgis-user mailing list
___________________________
Sebastian "Bas* " Gutwein
*rhymes with Josh
Regenerative Design Group
1 Chevalier Ave
Greenfield, Ma 01301
Web: regenerativedesigngroup.com
(631) 241-1018
*Look close, think big, make change. *
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220803/e8ca49fa/attachment.htm>
