[Qgis-user] Shape of parcel
Hernán De Angelis variablestarlight at gmail.com
Thu Aug 11 06:15:40 PDT 2022
On solution could be to split the polygons into segments while being
careful to keep track of which original polygon each segment was part
of, for example using an attribute. Then you can calculate the length o
each segment and classify them.
/H.
Den 2022-08-11 kl. 14:57, skrev Jon via Qgis-user:
> Hello,
> Is it possible to sort a shapefile by certain lengths of the shape
> sizes? Say I wanted to review only those shapes that are between 100'-
> 150' per side, is something like that possible? Or because some shapes
> are irregular, have the same criteria but it must match at least 3-4 of
> the sides.
> I don't think something like this is possible but figured I would post
> the question and see. Maybe there will be an answer saying no but
> leading me on another rabbit hole. :)
> Thanks for any help,
> Jon
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220811/df81b7c1/attachment.htm>
