[Qgis-user] Tectonic plate boundaries
chris hermansen clhermansen at gmail.com
Fri Aug 19 07:06:41 PDT 2022
John and list,
On Fri, Aug 19, 2022 at 2:45 AM John Moyle via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Thank you one and all with helpful suggestions about finding a shape file
> of tectonic plate boundaries.
> Having tried several of them, QGIS accepts them and allows me to set
> colour type and thickness of line etc but even if they are the only layer
> selected I am unable to *see *them.
This might be a problem with your coordinate reference systems (CRS) for
the two layers and the project.  Maybe one layer or the other doesn't
correctly specify a CRS?
If you click on Help on the main menu, which pops up the documentation for
the version you are using in your browser, you can go to the section on
"Working with Projections" (it's § 10 in my QGIS version).  There you will
find a gentle explanaton of the topic and how to problem-solve when
something goes wrong.
If this doesn't help come back for more.
> I must be doing something wrong!
> Maybe it's "old dogs and new tricks" at 77 to learn QGIS. The problem is
> that this is probably the only time I will ever be using a GIS and all the
> courses available want to teach so much general GIS before the little bits
> that I need to learn!!  I have my base raster file of the North Atlantic
> and have learned enough to make individual layers of cable interruptions,
> sub-sea volcanoes and land-slides etc. but have come unstuck at an *imported
> *shape file!
> Take heart, sounds like you've done all the hard stuff!
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220819/28747596/attachment-0001.htm>
