[Qgis-user] edit QGIS3.ini with startup.py
Stefan Giese (WhereGroup)
stefan.giese at wheregroup.com
Mon Dec 5 05:25:49 PST 2022
Hi Thomas,
you can clear the section before adding the new values with:
/QgsSettings().remove('svg/searchPathsForSVG')/
and then add your values
Best regards
Stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 05.12.2022 um 13:40 schrieb Thomas Schüttenberg via Qgis-user:
> Hi there!
> Because our servers have moved, the search paths for SVGs have changed. Unfortunately what we didn't think about before is that these old, wrong paths are (still) in the QGIS3.ini of the local user profiles and now cause eternal delays at startup because of their unreachability.
> We already use a startup.py to add file paths in centralized manner, like this
> gdi_global_svg = 'L:/Daten/geoservice/config/qgis_global_settings/svg'
> svg_paths = QgsSettings().value('svg/searchPathsForSVG')
> if gdi_global_svg in svg_paths:
> pass
> else:
> svg_paths.append(gdi_global_svg)
> QgsSettings().setValue('svg/searchPathsForSVG', svg_paths)
> Despite my still lacking Python knowledge, I thought one could easily include a corresponding fix (e.g. search and replace) in the startup.py script...
> I am still googling but maybe someone could help me with this, please? That would save my day!
> Best regards
> Thomas
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Stefan Giese
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
www.wheregroup.com
Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221205/488b5b57/attachment.htm>
