[Qgis-user] QGIS Error qgis_app.dll
Kinberger, Marvin
Marvin.Kinberger at gkd-re.de
Wed Dec 7 08:08:51 PST 2022
I have now placed an opencl.dll in the bin directory of the qgis installation. Unfortunately without success. the error keeps coming.
Based on the evaluation with depends.exe, I can also see that the opencl.dll from the system32 directory is being used. this shows the log.
I also do not recognize any dll in the log that is somehow conspicuous or missing.
does anyone have a hint?
Marvin
-----Ursprüngliche Nachricht-----
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Jürgen E. Fischer via Qgis-user
Gesendet: Mittwoch, 7. Dezember 2022 10:59
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] QGIS Error qgis_app.dll
Hi Marvin,
On Wed, 07. Dec 2022 at 09:22:21 +0000, Kinberger, Marvin via Qgis-user wrote:
> Hi, I have a problem with a central QGIS installation. I installed
> QGIS on a network drive using the OSGeo4W installer. Some clients can
> work with it without problems. On others, however, an error occurs when starting QGIS.
> "Could not load qgis_app.dll"
> I have already checked all the information in the qgis-ltr-bin.env.
https://github.com/qgis/QGIS/issues/26891#issuecomment-495889169
opencl.dll might be an issue - if the machine you installed on/from has a newer opencl.dll in system32 it's removed from OSGeo4W, but might be missing on some clients.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
More information about the QGIS-User
