[Qgis-user] Georeferencer Problem
boxerg at iinet.net.au boxerg at iinet.net.au
Wed Dec 7 15:44:04 PST 2022
I am having issues with the georeferencer. When I register an image the
process does not recognise the CRS entered into the settings window. It
returns the layer with an invalid projection. When I try to change the
projection in the new layer it creates this error.
Has anyone else had this problem? See output below, Any thoughts?
Regards Grant Boxer, Perth WA
An error has occurred while executing Python code:
RuntimeError: The JPEG driver does not support update access to existing
datasets.
  File
"C:\Users/boxer/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\e
nmapboxplugin\enmapbox\qgispluginsupport\qps\layerconfigwidgets\gdalmetadata
.py", line 1218, in apply
    ds = gdalDataset(self.mapLayer(), gdal.GA_Update)
  File
nmapboxplugin\enmapbox\qgispluginsupport\qps\utils.py", line 829, in
gdalDataset
    return gdalDataset(dataset.source(), eAccess=eAccess)
  File
nmapboxplugin\enmapbox\qgispluginsupport\qps\utils.py", line 833, in
gdalDataset
    ds = gdal.Open(dataset, eAccess)
  File "C:\OSGeo4W\apps\Python39\lib\site-packages\osgeo\gdal.py", line
4708, in Open
    return _gdal.Open(*args)
datasets.
Python version: 3.9.5 (tags/v3.9.5:0a7dcbd, May  3 2021, 17:27:52) [MSC
v.1928 64 bit (AMD64)]
QGIS version: 3.28.1-Firenze Firenze, fde3b8fbb8
Python Path:
*                     C:/OSGeo4W/apps/qgis/./python
C:/Users/boxer/AppData/Roaming/QGIS/QGIS3\profiles\default/python
C:/Users/boxer/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins
*                     C:/OSGeo4W/apps/qgis/./python/plugins
*                     C:\OSGeo4W\bin\python39.zip
*                     C:\OSGeo4W\apps\Python39\DLLs
*                     C:\OSGeo4W\apps\Python39\lib
*                     C:\OSGeo4W\bin
C:\Users\boxer\AppData\Roaming\Python\Python39\site-packages
*                     C:\OSGeo4W\apps\Python39\lib\site-packages
*                     C:\OSGeo4W\apps\Python39\lib\site-packages\win32
*                     C:\OSGeo4W\apps\Python39\lib\site-packages\win32\lib
*                     C:\OSGeo4W\apps\Python39\lib\site-packages\Pythonwin
C:\Users/boxer/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\en
mapboxplugin\site-packages
mapboxplugin
C:\Users\boxer\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\en
mapboxplugin\enmapbox\site-packages
mapboxplugin\enmapbox\apps
mapboxplugin\enmapbox\coreapps
mapboxplugin\enmapbox\eo4qapps
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221208/ab31bba4/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221208/ab31bba4/attachment-0001.png>
More information about the QGIS-User mailing list
